Little 2 stroke Rotella
I run t4/t6 on all my dirt bikes/boats/utv's.
This is my first 2 stroke though and I see things are a little different.
What oils can I run in the top reservoir and the bottom one?
For the top one, manual says 2 stroke JASO FC grade. None of the Rotellas have that certification. So what can I get instead at a place like Walmart..
For the Bottom one, it says 10w30 and no certification spec. Can I run T4/T5/T6? I remember there may be some compatibility issues with wet clutches on certain grades. All three of those come in 10w-30, although the most common is 15w-40 that people run in dirt bikes.
Advice?
If it matters, I live in AZ where the rides are all in temps between 60-115.
I am a big fan of Rotella T5 in my transmission. It is JASO MA for wet clutches, as well.
I would expect Rotella will work fine in your applications.
What premix are you running in the fuel?
I use the walmart stuff
It's my first 2 stroke and the previous owner gave me a bottle of yamalube 2s for the engine oil compartment (pw50 doesn't call for premixed). I could always just Amazon a gallon of the Yamalube 2s...I'm guessing it doesn't use THAT much anyways on that little thing...
Any 2T pre mix oil will work fine. Yamalube is good stuff. I use walmart brand.
Yes, if it's injected from another reservoir, then just pour it there.
