Another jetting problem.... Maybe?
That's just it tho, I don't even know which way to go. Plug was oily so I'd say too rich. It almost seems like something else entirely is going on though
with the oily plug and smoke maybe its a bad main seal...also if main seal goes out often times the bearing is getting loose causing crank wobble which leads to seal going out.
take it down to the primary gear and pressure up the cylinder. Squirt some soapy water where ever you think you might have a leak, then spray it everywhere it is possible to spray it and check.
