Best cleaner for us lazy types......
i usually just use hot water and what ever is around at the time. was using the local car was and just being careful around the seals with the high pressure and using the foaming brush and whatever soap they use.
a little preventative tip(great right before a muddy race too) is to spray the undersides of your plastics with wd-40. seriously, keeps the mud from caking up and in a race that means a lot less weight you're lugging around too :thumb:
also if you clean your bike after EVERY ride then every time you clean it is easier than letting it sit a few rides and letting everything get hard and build up.
:thumb: I've been know to put some PAM under the fenders and such.
Something you won't find at Stater Bros, but works really good, is Bike Bright. Hose your bike off, spray it on, maybe a little brush work on the bad areas, and rinse it back off.:thumb:
