Now you are getting there .....
I think you're good. The larger piece is 15 and what looks like a washer is probably a bearing (13). Does it turn freely? Can you pull it off the larger part - be careful bearings may fall out.
Okay, I know that the basket and hub do spin separately, ill try the rest out tomorrow or SaturdayYou may have said that you tried this, but I'm not sure - If you have all of the clutch plates out, pressure plate and springs out, and the bike is in neutral, can you spin the inner and outer clutch baskets independently? #5 and #1 will spin separately - you can spin one, one way, and spin the other the opposite direction without them both spinning together? Just trying to see if the inner and outer baskets are somehow stuck together. Kinda running out of ideas here and without seeing it, not sure where to go.
If that works, you could slowly build from there to see where the problem is. Try putting the plates in and the pressure plate on, leaving the springs off, and see if you can rotate the outer clutch basket with the kickstarter with the bike in gear and the back wheel on the ground or immobilized. If that works, then it's got to be something in the pressure plate/springs/those pieces we've looked at to disengage the pressure plate. One other thing I thought of looking at that picture; the pressure plate isn't hitting against anything, blocking it from coming out when the side cover is installed with everything in place; is it?
I dont think it's the plates, through out the whole process any time I took them out I put them back in 1 by 1. And when it was in gear and I used the kick start without the springs the steels spun separate from the fibers no problem. And they were and still are soaked. I guess one of my last options is to just let it run in neutral for a good 30 minutes before putting it into any gear and see what happens. I mean one of the most basic things to do but I'm at a loss right now. If that doesn't work I'll have to look into a shopNot sure what to tell you. If you have the bike in gear, wheels on the ground, and the clutch lever pulled in, can you roll the bike forward or backwards without the rear wheel skidding like it's locked up? Don't know if that may break something loose or give you an idea what's going on. Only other suggestion is to pull out one each of the plates, put it all together and see if it does the same thing. Don't try to run it that way, just trying to see if it's the plates locking things up.
