The oil's molecular structure is expanding due to heat, but since an engine doesn't get anywhere near the boiling point of oil, IMHO, the rise in volume will be extremely minimal.
I think the 'Viscosity Improvers' and 'pour point depressant' additives in multi-viscosity oil are changing the Viscosity of the oil and manipulating how the oil moves through the engine, giving different readings (on a dipstick or sight glass) as the temperature changes. Examples: Surface tension making the oil 'climb' the walls.
EDIT: Another thing I thought of as the engine heats up it expands as well. Could this possible cause the oil level to rise as the volume of storage decreases?
-BIG DAN
LOL so the volume of a pan gets smaller as the pan heats up? I know you are including the other components as well. I can believe you can see it change. I am still considering the tt that rez menioned and the hondas I am familiar with more frequently and how they maintain and oil level in coolers and and frame reservoirs and how it changes from sitting overnight to just run. It isnt heat affected enough to change the visible levels and certainly not on the 10 to 15% levels to make a sight glass on a system that is less than a quart and a half go up or down a quarter of the sight glass window.
