RM250 rm250 starting issues
Kick starter reassembly:
fit the kick drive gear and washer to the kick shaft. Fit the circlip firmly with snap ring pliers
fit the return spring into the kick shaft hole.
fit the spacer.
fit the kick starter to the kick starter shaft.
NOTE: Be sure to align the punch marks on the kick starter and kick starter shaft when fitting the kick starter.
Fit the kick starter assembly to the crank case. Hook the return spring.
Reassemble the kick idle gear.
Thats it.
No.. I didnt do that.. Im pretty positive they never come apart though.. I will check thought... I didnt check them for sure...But i will
Thanks homie!
