Superbike in Evansville IN, They do all engine work,and performance work. They have engine dyno's and bike dyno's. They port matched and was going polish , But it was already done, They cleaned up some stuff.
So how much was it all together?
If he has to split the cases to fix the bearing, I willNot to be a dick but I just noticed this... but on my countershaft bearing the bearings are towards the center of the cases so they can be fed oil.... Zook uses alot of 1 way bearings, always has.
awesomeOh yeah, My buddys graphics kit that you were wondering about for the KX is from attackgraphics.com
And thanks for the head pipe, Works perfectly! And i cut the insides out of one of my old FMF powercores and rebuilt the kx silencer and stuffed it with some insulation from my buddys garage roof![]()
If he has to split the cases to fix the bearing, I will![]()
how is saving him from a horrible motor failure being a dick?Not to be a dick but I just noticed this... but on my countershaft bearing the bearings are towards the center of the cases so they can be fed oil.... Zook uses alot of 1 way bearings, always has.
its a cycra skull plate...Its off a 04rm125, I've got a new black fender for a 04125 coming...
Do you like the number plate or no? I like it..It will like clip into the new fender
im not digging itIts off a 04rm125, I've got a new black fender for a 04125 coming...
lolwut?Not to be a dick but I just noticed this... but on my countershaft bearing the bearings are towards the center of the cases so they can be fed oil.... Zook uses alot of 1 way bearings, always has.
What i meant, Was the countershaft bearing has no seal built into it.lolwut?
Thats not a one way bearing, Unless im missing something. The coutershaft bearing has no seal on it. Thats what i was waiting for.
Did all the heat cycles and everything seems ok, Made it about a mile before it started spitting and sputtering... Guess i fouled the plug i'm assumming , Will have to look at it tomorrow.
What i was waiting for was 26,33,34,35,... And i got those today and installed them.
lolwut?
