OK thanks, I think that helps. We,ll see.
This what you mean by changing the seal?
http://www.thumpertalk.com/topic/317828-how-to-change-your-crank-seal/
OK, yeah I finally got it. Set it to the top and reassembled, don't think it made a difference.
How exactly do I adjust the float level? Still can't figure it out.
What way should I bend the Tang on the float so it won't flood? I bent it up a bit, think I read that would lean it out.
OK. Good to hear, after putting in a new plug and cleaning the carb and being able to ride it a bit more I think I got more consistent results of the problem.
When I take off at first 1 lap up the road it seems fine, but at some points feels like its holding back powerwise, then picks up again, by second time down it'll hit a point trying to give it throttle bogs it, letting go of throttle straightens out again.
